EUROPEAN
Bugatti Veyron W16
Engine Configuration W
Cylinders 16
Aspiration/Induction Quad Turbo
Displacement 7993.00 cc | 487.8 cu in. | 8 L.
Valves 64 valves.
4 valves per cylinder.
Valvetrain DOHC
Horsepower 1001.00 BHP (736.7 KW) @ 6000.00 RPM
Torque 922.00 Ft-Lbs (1250.2 NM) @ 2200.00 RPM
HP to Weight Ratio 4.5 LB / HP (Vehicles with similar ratio)
HP / Liter 125.1 BHP / Liter
Porsche Carrera GT
Engine Configuration V
Cylinders 10
Aspiration/Induction Normal
Displacement 5.70 L | 347.8 cu in. | 5700.4 cc.
Horsepower 605.00 BHP (445.3 KW) @ 8000.00 RPM
Torque 435.00 Ft-Lbs (589.9 NM) @ 5750.00 RPM
HP to Weight Ratio 5.0 LB / HP (Vehicles with similar ratio)
HP / Liter 106.1 BHP / Liter
FERRARI FXX
65-degree
Cylinders 12
Engine Aluminum,
Displacement 6262.00 cc | 382.1 cu in. | 6.3 L.
Valves 48 valves.
Valvetrain DOHC
Horsepower 800.00 HP (588.8 KW) @ 8500.00 RPM
HP / Liter 127.0 BHP / Liter
AUDI R8
Cylinders 8
Displacement 4163.00 cc | 254 cu in. | 4.2 L.
Horsepower 420.00 BHP (309.1 KW) @ 8205.00 RPM
Torque 317.00 Ft-Lbs (429.9 NM) @ 5500.00 RPM
HP / Liter 100.0 BHP / Liter
Koenigsegg CCX
At the end of 2008 Lotus will unveil an entirely new Esprit with a “versatile vehicle architecture” aluminum construction technique. The new Esprit is known as MSC and will come to compete with models like Porsche 911 Turbo and Audi R8. It iwll be priced at $130000.
The Esprit will be powered by a V8 turbo charged engine with an output of 400hp.
Lotus.
2006 Mercedes-Benz SLR "722 Edition"
The supercharged 5.5-liter V8 engine in the 722 Edition, which is hand-built in the AMG engine shop in Affalterbach, generates 650 bhp. The particular strengths of this high-performance engine are immediate response to movements of the accelerator, highly emphatic torque build-up and an unmistakable V8 sound. The performance figures are outstanding even for a high-end sports car: the 722 Edition accelerates from standstill to 62 mph in only 3.6 seconds, and 124 mph is reached in just 10.2 seconds. The top speed (209 mph) is above the 207 mph previously achieved by the SLR.
MB.
JAPANNissan R390 GT-1
Engine VRH35L V 8
Engine Location Mid , longitudinally mounted
Displacement 3.496 liter / 213.3 cu in
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Fuel injection
Aspiration Twin Turbo
Gearbox Xtrac 6 speed Manual
Drive Rear wheel drive
Performance figures
Power 560 bhp / 418 KW @ 6800 rpm
Torque 638 Nm / 471 ft lbs @ 4400 rpm
BHP/Liter 160 bhp / liter
Power to weight ratio 0.55 bhp / kg
Top Speed 330 km/h / 205 mph
0-60 mph Acceleration 3.8 s
Toyota GT-1
engine Twin Turbo V8
displacement 3600 cc / 219.7 cu in
bore 86.0 mm / 3.39 in
stroke 77.0 mm / 3.03 in
compression 9.0:1
power 447.4 kw / 600.0 bhp @ rpm rpm
hp per litre 166.67 bhp per litre
bhp/weight
torque 650.0 nm / 479.4 ft lbs @ rpm rpm
body / frame Carbon Fibre Composite
front brakes Carbon Fibre Discs
rear brakes Carbon Fibre Discs
Acura ALMS
I know this isn't top of the fast lane. but ... I LOVE IT !!!
hu hu hu
